I own a 6 year old Frigidaire gas dryer model number GLGQ332AS2 and recently all of a sudden the dryer stopped heating. Everything else works, the light inside of it turns on, the drum spins when I turn on the machine, but it simply will not produce any heat! I cannot ever hear that my dryer is trying to turn on the heating element..... What could be wrong with it and how would I be able to fix it? I read that thermal fuse may be causing this. If there is a thermal fuse in my dryer then where is it located and how do I take my machine apart to get to it? Any suggestions greatly appreciated.... Thanks in advance! Maria
Originally Posted by: maria23  I own a 6 year old Frigidaire gas dryer model number GLGQ332AS2 and recently all of a sudden the dryer stopped heating. Everything else works, the light inside of it turns on, the drum spins when I turn on the machine, but it simply will not produce any heat! I cannot ever hear that my dryer is trying to turn on the heating element..... What could be wrong with it and how would I be able to fix it? I read that thermal fuse may be causing this. If there is a thermal fuse in my dryer then where is it located and how do I take my machine apart to get to it? Any suggestions greatly appreciated.... Thanks in advance! Maria Here it is April 2011 and I have the same problem with the same model gas dryer. Any advice? The product manual mentions that one of the two fuses could be out? How do I get replacement fuses and where do they go exactly?
