washer fills with water when off. already changed the inlet valve assembly but problem continues.
What is the complete model number of the washer?
Originally Posted by: ajk106 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) washer fills with water when off. already changed the inlet valve assembly but problem continues. model number is 11047512600
Remove the wires from the water inlet valve. If the water will stop, replace the CCU. If the water would not stop, the water inlet valve is defective. - The CCU Part number: AP4434555
