ajk106
#1 Posted : Thursday, August 19, 2010 7:20:44 AM(UTC)
ajk106
washer fills with water when off. already changed the inlet valve assembly but problem continues.
#2 Posted : Thursday, August 19, 2010 10:51:02 AM(UTC)
What is the complete model number of the washer?
ajk106
#3 Posted : Thursday, August 19, 2010 11:00:58 AM(UTC)
ajk106
model number is 11047512600
#4 Posted : Thursday, August 19, 2010 12:56:53 PM(UTC)
Remove the wires from the water inlet valve.
If the water will stop, replace the CCU.
If the water would not stop, the water inlet valve is defective.
- The CCU Part number: AP4434555
- The water inlet valve Part number: AP3866046
Washer fills when off (Washer Repair)
by kbncpa 11/4/2007 8:57:25 AM(UTC)
