A few days back I turned up the fridge and freezer to max cool. Today I came home to a good freezer and warm fridge. I checked the intake on the bottom by the produce drawer and saw the coils were frozen. Now I just turned both the dampers to low in hopes it will defrost and be fine. Could this be the solution? Was the problem I had it up too high and it caused frost build up and clogged the intake to the fridge?
