ownoeljr
#1 Posted : Sunday, August 31, 2008 12:25:50 PM(UTC)
ownoeljr
The bottom portion of the freezer and refridgerator are cooling properly, however the top portion of both are not cooling. Could it be the evaporator fan? Very little cool air is coming in through the top vents.
abadfish66
#2 Posted : Sunday, August 31, 2008 12:35:22 PM(UTC)
abadfish66
Yes, the freezer fan is not moving the air like it should, you will need a new main board, not a fan, to fix this problem. WR55x10552 is the part# needed
abadfish66
#3 Posted : Sunday, August 31, 2008 12:35:59 PM(UTC)
abadfish66
This is assuming you don't have a ton of frost on the back wall of the freezer.
ownoeljr
#4 Posted : Sunday, August 31, 2008 12:43:23 PM(UTC)
ownoeljr
Yes, there was frost on the back. I unplugged the unit and used a hair dryer to remove the ice from the coils.
