AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Can I replace part 8564899 (Track Mount) for holding cutlery tray track myself?
The clip holding the wheel in place on this part is broken. Is it possible for me to replace this part myself without affecting the water seal since this part mounts into the tub? How would I go about doing this? I don't want to force the part out and I cannot readily see how this piece is mounted on the dishwasher tub. Do I need to pull out the entire dishwasher so I can access the mounting on the outside of the dishwasher?
Never had problems with this rack but I believe its design should be very similar.
Hello Gene, reading here you may have helped with this same scenario before. I have the kitchenaid kuds03fsss3 dishwasher. the 3rd row mount track on the right side is broken. there do not appear to be any screws holding in this mount. how does it release from the inside? thanks!
Hello,
I believe there are screws and you have to remove the dishwasher from the cabinet to access them.
I'll take a look and see if this is the case. I do not have the part yet, when I do, I'll check it out. thanks!
Dishwasher Repair
