Bay Area John
#1 Posted : Tuesday, August 17, 2010 12:20:18 PM(UTC)
Bay Area John
Like a firecracker...the red indicator light on our Whirlpool Electric Cooktop (model # rcs3004rs00) just exploded! LITERALLY!
Anyone out there experienced such an issue? Suggestions?
I went ahead & ordered the part, but I'm wondering if maybe I ought to do some troubleshooting prior to installing the new indicator light, so I don't explode it too!
I'm pretty handy with a mulitmeter & Dad's an electrician.
Thanks in-advance for your insight.
-Bay Area John
Joe / APP Team
#2 Posted : Tuesday, August 17, 2010 12:36:42 PM(UTC)
Joe / APP Team
-Bay Area John
Did someone have a boil over,spillover, or get the cooktop wet, somehow ?
Based on the wiring diagram, I think that is a 240 VAC indicator light.
(no switch circuitry, in diagram).
Do all the burners work ?
You may want to visually check the burner receptacles for damage and the switches and wiring as well, before you install the new light.
:cool: :cool: :cool:
Bay Area John
#3 Posted : Tuesday, August 17, 2010 2:51:31 PM(UTC)
Bay Area John
Joe M.,
Thanks for your response to my question about the exploding indicator light.
I will investigate, like you suggested...before replacing the part with a new one.
I wonder what the easiest way to replace it is...maybe remove the cooktop somehow????...I don't know...never done it before.
Thanks!
Bay Area John
Joe / APP Team
#4 Posted : Wednesday, August 18, 2010 6:26:47 AM(UTC)
Joe / APP Team
-Bay Area John
John,
Attached the service manual for you to review and use as you need to.
It covers several models, including yours, and should get you through the repair pretty easy.
Good luck
http://servicematters.com/tech_ref/JA/ja_main.htm
tboodro
#5 Posted : Tuesday, December 11, 2012 4:06:16 PM(UTC)
tboodro
John!
This just happened to my wife and I while cooking dinner. It looks like it tripped the breaker. And I'm scared to turn it back on.
Do you remember what it took to fix your stove? Was it ruined or did you just have to replace the little bulb?
Thanks,
Todd
Joe / APP Team
#6 Posted : Wednesday, December 12, 2012 6:35:16 AM(UTC)
Joe / APP Team
Originally Posted by: tboodro Go to Quoted Post
John!
Thanks,
Todd
Todd, If the unit shorted and tripped the breaker, this would indicate a short to ground. You'll need to turn the power off, raise the cooktop and check the wiring at the switches and indicator lights to see if you had moisture or water in the wiring,and switches from a "spill over". All these circuits are 220/240 VAC, so be careful, and make sure the power is "OFF" before you start.
