david braun
#1 Posted : Wednesday, August 27, 2008 10:47:59 AM(UTC)
david braun
When I push the start button, the rinse only light flashes. Nothing else happens. Push cancel and the cancel light flashes, but nothing else happens.
I removed all the wires on the control paanel and reattached them and it worked for one cycle but is now dead again.
#2 Posted : Wednesday, August 27, 2008 5:47:07 PM(UTC)
Hi David,
Most likely the problem is a stuck one or more pad(s) on the key pad which is a part of the control panel.
In order to provide the right part number I need the color of it.
Here are the break down diagrams for the Kitchen Aid dishwasher Model KUDI01TJBL0
libertyappl
#3 Posted : Wednesday, August 27, 2008 6:27:47 PM(UTC)
libertyappl
You have been a member since:: 8/13/2008(UTC)
This is from the tech sheet.
STUCK KEY: If the control detects that a key is stuck in the depressed position,
dishwasher operation will be suspended and the control will flash the
light for that key until the condition is corrected. If a key without a light is
stuck or multiple keys are stuck, the control will flash the light for the Rinse
Only/Quick Rinse key.
