MATT1946
#1 Posted : Friday, August 13, 2010 5:38:45 AM(UTC)
MATT1946
Water On Floor Hear It Running Doesn't Get Cold
#2 Posted : Friday, August 13, 2010 6:06:33 AM(UTC)
Here are the parts
Replacement parts for FRIGIDAIRE LFFU1765DW3 Frigidaire/freezer | AppliancePartsPros.com
Water could be from the frost in the unit, it has overflowed the drain cup.
Also the compressor line running in the drain cup helps with evaporation of the water so if the compressor is not cooling this line never gets warm.
Double check that the compressor is running, it should be warm and you should be able to feel it vibrating.
If yes
Check to be sure that the evaporator fan is running.
Remove the cover so you can see the evaporator coils.
If there is no frost on the coils your sealed system is toast.
If there is just frost in one area (usually where the freon enters the coils) or it is blotchy then you are likely low on freon.
Of coarse the above is also dependent on how long it has been since a defrost cycle.
Either of the above is an expensive repair and it is probably better to put those dollars toward a new unit.
LG Fridge - Air condensing at back of freezer (Refrigerator & Freezer Repair)
by Guest 6/25/2024 5:44:16 AM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Mysterious leak -Top Freezer w/Ice maker (Refrigerator & Freezer Repair)
by St.B 6/18/2024 8:40:52 AM(UTC)
GE bottom freezer model #: PFE28KBLTS not cooling well and no ice (Refrigerator & Freezer Repair)
by Danny1976 6/7/2024 12:43:43 PM(UTC)
GE bottom freezer not cooling well and no ice (Refrigerator & Freezer Repair)
by Guest 6/7/2024 7:31:51 AM(UTC)
Ice block in freezer (Refrigerator & Freezer Repair)
by bassbuddy25 6/5/2024 12:10:09 PM(UTC)
Freezer is cooling ok- top shelves in fridge ok, lower shelves in fridge too warm (Refrigerator & Freezer Repair)
by Guest 6/5/2024 11:24:33 AM(UTC)
Kenmore 106.74203402 fridge/freezer not cooling (Refrigerator & Freezer Repair)
by ryancg 5/26/2024 7:58:26 PM(UTC)
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 5/16/2024 12:29:58 PM(UTC)
Freezer Help from Whirlpool Unit (Refrigerator & Freezer Repair)
by Guest 5/15/2024 5:37:40 AM(UTC)
Water Dribbing into Freezer (Refrigerator & Freezer Repair)
by mbc320 5/14/2024 3:39:48 PM(UTC)
KitchenAid freezer gasket needed (Refrigerator & Freezer Repair)
by Kris Ballew 4/30/2024 6:27:57 PM(UTC)
Samsung Rs261MDWP Freezer Evap fan (Refrigerator & Freezer Repair)
by Jben04 4/29/2024 12:37:29 PM(UTC)
Electrolux fridge compartment not cooling, freezer is cold (Refrigerator & Freezer Repair)
by Minthook 4/22/2024 8:17:01 AM(UTC)
