shloime
#1 Posted : Tuesday, August 26, 2008 12:23:27 PM(UTC)
shloime
Our float is detached from the lever actuator but the palnut is attached to the float. How do i attach the float to the lever?
#2 Posted : Wednesday, August 27, 2008 12:19:21 PM(UTC)
Most likely the stem of the float is broken. Normally it just goes through and pushes the switch when there is no water.
The float
UserPostedImage
Here are the break down diagrams for the Maytag dishwasher Model MDB5000AWB
shloime
#3 Posted : Thursday, August 28, 2008 10:50:10 AM(UTC)
shloime
I dont see anything broken Is the the float suppose te pull up the actuator lever to stop too much incoming water?
shloime
#4 Posted : Thursday, August 28, 2008 10:52:43 AM(UTC)
shloime
Is the float suppose to pull up the actuator lever?
#5 Posted : Thursday, August 28, 2008 5:23:42 PM(UTC)
The float pushes on the switch under the dishwasher when there is no water, causing the switch to close the circuit for the water valve.
If the float comes up with water, it releases the switch, causing the circuit to open.
