Hi, I have the same problem as described in this thread http://forum.appliancepartspros...-not-turning-washer.htmlI've located the part from a local supplier, but I already know that none of the socket wrenches I have are big enough to encompass the bolt (my largest is 7/16-in). What size socket wrench do I need to handle the bolt the holds the auger on the base? And is there anything special I need to know about replacing the auger? Do I just screw the bolt back in very firmly? Thanks.
