hoodsmom
#1 Posted : Thursday, August 12, 2010 8:12:18 AM(UTC)
hoodsmom
Hi, I have the same problem as described in this thread
http://forum.appliancepartspros...-not-turning-washer.html
I've located the part from a local supplier, but I already know that none of the socket wrenches I have are big enough to encompass the bolt (my largest is 7/16-in). What size socket wrench do I need to handle the bolt the holds the auger on the base?
And is there anything special I need to know about replacing the auger? Do I just screw the bolt back in very firmly?
Thanks.
icemaker auger replacement (Refrigerator & Freezer Repair)
by glassesgirl57 10/26/2009 1:54:36 PM(UTC)
Ice maker auger replacement (Refrigerator & Freezer Repair)
by billshirey 4/6/2009 3:34:41 PM(UTC)
ice maker auger replacement (Refrigerator & Freezer Repair)
by mannblk2003 1/3/2009 7:17:42 AM(UTC)
GE Icemaker Auger replacement (Refrigerator & Freezer Repair)
by bschachter 7/23/2008 1:39:41 PM(UTC)
