gfroman
#1 Posted : Wednesday, August 11, 2010 7:53:34 AM(UTC)
gfroman
:( Today the dryer will not even start. Do we need a new drive motor?
#2 Posted : Wednesday, August 11, 2010 12:02:12 PM(UTC)
The first thing you may want to do is to take the dryer apart and check the front glides and pads (#13 & #14 on the diagram) and rear drum support rollers (#18 on the diagram).
Check the blower wheel (#8 on the diagram) and clean the dryer exhaust line all the way through the vent outlet.
- The glide (have to order two) Part number: AP4046795
- The felt pad (have to order two) Part number: AP4054015
- The roller (have to order two) Part number: AP4046756
gfroman
#3 Posted : Friday, August 13, 2010 7:24:56 AM(UTC)
gfroman
Gene the dryer will not even start today! Do we need to replace the drive motor?
