:( Today the dryer will not even start. Do we need a new drive motor?
The first thing you may want to do is to take the dryer apart and check the front glides and pads (#13 & #14 on the diagram) and rear drum support rollers (#18 on the diagram). Check the blower wheel (#8 on the diagram) and clean the dryer exhaust line all the way through the vent outlet. - The glide (have to order two) Part number: AP4046795
Originally Posted by: Gene  The first thing you may want to do is to take the dryer apart and check the front glides and pads (#13 & #14 on the diagram) and rear drum support rollers (#18 on the diagram). Check the blower wheel (#8 on the diagram) and clean the dryer exhaust line all the way through the vent outlet. - The glide (have to order two) Part number: AP4046795
- The felt pad (have to order two) Part number: AP4054015
Gene the dryer will not even start today! Do we need to replace the drive motor?
