TommyG
#1 Posted : Monday, August 25, 2008 10:07:47 AM(UTC)
TommyG
When I turn on any of the cook top burners, the spark igniter will click away but wont light the burners. I can light them manually so it is not a fuel problem. What is the most likely cause?
libertyappl
#2 Posted : Monday, August 25, 2008 12:35:49 PM(UTC)
libertyappl
Hi
Is probably the spark ignitor. part number AP4010034.
Nat
Intermittent burner ignition (Oven Repair (including Ranges and Cooktops))
by ravernon 6/25/2009 8:33:44 AM(UTC)
Top burner ignition module (Oven Repair (including Ranges and Cooktops))
by Driscol 9/8/2008 11:32:55 AM(UTC)
burner ignition has a mind of its own (Oven Repair (including Ranges and Cooktops))
by Laura 4/20/2008 7:05:59 AM(UTC)
GE Profile Burner Ignition Inconsistant (Oven Repair (including Ranges and Cooktops))
by nycphog 12/3/2007 1:59:07 PM(UTC)
