All four burner controls ignite the rear right burner. I'm guessing I need a new Spark module but I'm not sure. This problem occurred when I replaced the glass top.
Part Number: AP3778816 made by GE
All four burners should spark at the same time no matter which burner you turn on....that's just the way the newer gas ranges work. Replacing the spark module won't cure that.
Your reply doesn't help considering that before I replaced the glass top each dial would only ignite its respective burner. In other words it worked the same way it came.
I'm hoping someone has come across this problem before and knows what is wrong.
Well if you say that was the way it was working before you replaced the glass top, common sense says you did something wrong so your going to have to check over your work and make sure you haven't pinched any wires somewhere and none are touching ground (cabinet) anywhere. Sorry if I am no help...only been a GE service tech for 18 years.
