murphk1
#1 Posted : Monday, August 9, 2010 4:31:22 PM(UTC)
murphk1
Whirlpool RBS305PDB14: Will not heat up. Control Panel has power (clock, timer etc. . . etc. ., after selecting a Bake Temp it sounds as if its heating up (just as in the past) but neither heating element warms up. I'm going to check the elements with a multi-meter (after turning off & tagging the breaker) but is appears to be something that controls/manages both elements as they both stopped heating the same day. What could that be --- thermister, or something else?
Any assistance is appreciated.
#2 Posted : Tuesday, August 10, 2010 2:09:29 AM(UTC)
Replacement parts for WHIRLPOOL RBS305PDB14 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208301757.pdf
Once you confirm that you have the full 240 volts, I would check for a burned wore or the thermal fuse.
