Whirlpool RBS305PDB14: Will not heat up. Control Panel has power (clock, timer etc. . . etc. ., after selecting a Bake Temp it sounds as if its heating up (just as in the past) but neither heating element warms up. I'm going to check the elements with a multi-meter (after turning off & tagging the breaker) but is appears to be something that controls/manages both elements as they both stopped heating the same day. What could that be --- thermister, or something else?
Any assistance is appreciated.
THIS FORUM IS DEAD!!!!!!! |
