scg0557
#1 Posted : Saturday, August 7, 2010 6:48:48 PM(UTC)
scg0557
I normally can raise and lower the Cook N Vent snorkel and the vent fan always works. Occasionally though the snorkel will be stuck in the up position. I had replaced the on/off switch previously and have determined that the switch works properly and is not the issue. Now when the snorkel is stuck in the up position I have to take the J box cover off and then press against the com terminal on the gear motor switch slightly and release. Then I hit the on/off switch and the snorkel retracts. Its good for several cycles and then I have to repeat the above. Is it a bad gear motor switch?
#2 Posted : Sunday, August 8, 2010 6:44:15 AM(UTC)
Here are your parts, includes a wiring diagram
Replacement parts for THERMADOR CVS45RS | AppliancePartsPros.com
[COLOR="Blue"]Is it a bad gear motor switch?[/COLOR]
Yes it could be the switch.
Could also be that the switch is a little loose and is backing out so it does not close consistently.
Also bending the switch activation arm a little so it pushes the switch in further may solve this.
wgfrench
#3 Posted : Sunday, January 16, 2011 12:45:27 PM(UTC)
wgfrench
I'm pretty sure that my similar problem is a bad microswitch. But I can't quite figure how to disassemble enough to replace it or bend the arm.
Are there assembly/disassembly instructions on the web somewhere?
My mdoel is CVS30RB
