Davidrod777
#1 Posted : Thursday, August 21, 2008 9:48:19 AM(UTC)
Davidrod777
Dryer has no heat and attempting to troubleshoot to replace needed parts but I'm unable to get pass the first step of removing panels to access the parts. I removed the screws in the rear and lower side panels. What else needs to be removed? :confused:
libertyappl
#2 Posted : Friday, August 22, 2008 8:18:38 AM(UTC)
libertyappl
Double check your model number, I can't pull up your breakdown.
Nat
Davidrod777
#3 Posted : Friday, August 22, 2008 8:34:46 AM(UTC)
Davidrod777
Opps! Model number is MDG7600AWW. I figured out how to remove the front panel and was able to access the parts and found the problem. Did a continuity check on the igniter and found it open. Replaced that and I my wife is happy again. When she's happy, the whole house is happy. Thanks!
libertyappl
#4 Posted : Friday, August 22, 2008 9:25:25 AM(UTC)
libertyappl
I always find that to be true.....lol
Nat
