Dryer has no heat and attempting to troubleshoot to replace needed parts but I'm unable to get pass the first step of removing panels to access the parts. I removed the screws in the rear and lower side panels. What else needs to be removed? :confused:
Double check your model number, I can't pull up your breakdown. Nat
Opps! Model number is MDG7600AWW. I figured out how to remove the front panel and was able to access the parts and found the problem. Did a continuity check on the igniter and found it open. Replaced that and I my wife is happy again. When she's happy, the whole house is happy. Thanks!
I always find that to be true.....lol Nat
