I have a Maytag Advanced cooking system Super Capacity plus. Model number MER5550AAH. I purchased a part AP4093422 (74003559) Latch, door lock and once I installed it I get a F3 fault code. what does this mean?
also I would like to find a diagram to be sure i connected the wires correctly, this may have Shorted the oven temperature sensor which i discoverd is likely the cause of the F3 fault code.
THIS FORUM IS DEAD!!!!!!! |
Thanks, I did have it wired correctly, now with the F3 fault code I should replace the Sensor, Oven ? Part Number: AP4009009 made by WHIRLPOOL
