Lano
#1 Posted : Friday, August 6, 2010 10:29:02 AM(UTC)
Lano
I have a Maytag Advanced cooking system Super Capacity plus. Model number MER5550AAH. I purchased a part AP4093422 (74003559) Latch, door lock and once I installed it I get a F3 fault code. what does this mean?
Lano
#2 Posted : Friday, August 6, 2010 10:44:27 AM(UTC)
Lano
also I would like to find a diagram to be sure i connected the wires correctly, this may have Shorted the oven temperature sensor which i discoverd is likely the cause of the F3 fault code.
#3 Posted : Sunday, August 8, 2010 7:49:29 AM(UTC)
Lano
#4 Posted : Monday, August 9, 2010 6:33:25 AM(UTC)
Lano
Thanks, I did have it wired correctly, now with the F3 fault code I should replace the Sensor, Oven ?
Part Number: AP4009009 made by WHIRLPOOL
#5 Posted : Monday, August 9, 2010 7:58:21 AM(UTC)
Yes it could be the sensor, you can check it with a meter.
See Items 7, 8, 20 and 21
http://www.applianceaid.com/elecrange.html
