I Have Replaced The Defrost Heater And Thermostat Because My Fridg Was Warm But Freezer Cold, This Is After Consulting With A "professional Qualified Tech", My Fridge Is Still Not As Cold As It Should Be. The Temp. Is Between 40-45+ Degrees What Else Could Be Causing This?
Originally Posted by: tators  I Have Replaced The Defrost Heater And Thermostat Because My Fridg Was Warm But Freezer Cold, This Is After Consulting With A "professional Qualified Tech", My Fridge Is Still Not As Cold As It Should Be. The Temp. Is Between 40-45+ Degrees What Else Could Be Causing This? Tators, Did you check the auto damper for ice or debris, and make sure the end of the temperature bulb was in the airflow (per my last post) ? If so, the only thing left would be a intermittent evaporator fan motor or faulty temperature control. There isn't much more to check or replace from there.:confused:
