tators
#1 Posted : Wednesday, August 4, 2010 12:19:34 PM(UTC)
tators
I Have Replaced The Defrost Heater And Thermostat Because My Fridg Was Warm But Freezer Cold, This Is After Consulting With A "professional Qualified Tech", My Fridge Is Still Not As Cold As It Should Be. The Temp. Is Between 40-45+ Degrees
What Else Could Be Causing This?
Joe / APP Team
#2 Posted : Wednesday, August 4, 2010 1:08:26 PM(UTC)
Joe / APP Team
Tators,
Did you check the auto damper for ice or debris, and make sure the end of the temperature bulb was in the airflow (per my last post) ?
If so, the only thing left would be a intermittent evaporator fan motor or faulty temperature control.
There isn't much more to check or replace from there.:confused:
