Robgw007
#1 Posted : Wednesday, August 4, 2010 1:44:40 AM(UTC)
Robgw007
I've already changed the heating element, main control board, and thermostat's. When I jumper the switch for heating (RL2) I get high heat. Can't see on the diagram what else could be related to the problem.
Joe / APP Team
#2 Posted : Wednesday, August 4, 2010 6:35:07 AM(UTC)
Joe / APP Team
Based on the information I have,and your information you probably have :
A broken red/ black wire from the themal fuse to the control board(J2-1) terminal.
A bad RL2 relay on the new control board.
I believe you'll find a bad relay, but check for 120 volts at the J2-1 terminal on the control board first.
* be careful, this is a live voltage test and you could hurt yourself *
Hope this helps
No heat from dryer (Dryer Repair)
by Cvfd626 4/20/2014 6:29:33 PM(UTC)
No Heat From Dryer (Dryer Repair)
by D3RDEYE 2/4/2013 10:34:50 PM(UTC)
no heat from dryer (Dryer Repair)
by bjmyers70 1/20/2010 11:10:38 AM(UTC)
by TimN 11/23/2009 9:48:47 AM(UTC)
no heat from dryer unit (Dryer Repair)
by stefanos 5/15/2009 8:43:16 AM(UTC)
No Heat from Dryer! (Dryer Repair)
by Voyager15 1/26/2008 9:00:26 AM(UTC)
