kertz3
#1 Posted : Sunday, August 17, 2008 2:15:11 PM(UTC)
kertz3
The washer in question had a piece of broken plastic between what i think are the motor and transmission under a rubber disk. It will drain water out of the machine without the basket turning. I don't see any belt under this washer. I f it is the transmission is it worth replacing? Thanks for any help anyone could provide.
iamigor5@yahoo.com
#2 Posted : Sunday, August 17, 2008 6:33:47 PM(UTC)
iamigor5@yahoo.com
the plastic part is a coupler that takes the place of a belt it costs under 15 bucks and is pretty easy to install
libertyappl
#3 Posted : Sunday, August 17, 2008 7:21:29 PM(UTC)
libertyappl
The coupling part number is AP3963893.
kertz3
#4 Posted : Monday, August 18, 2008 7:54:54 PM(UTC)
kertz3
I ordered the coupler. Anything else I should look at while I have it apart? Any tip on how to do the job?
libertyappl
#5 Posted : Tuesday, August 19, 2008 4:49:08 AM(UTC)
libertyappl
Basically once you have the front panel off the washer-unclip the pump pull it back out of the way, remove the coupler, replace coupler and put the pump back, install clips....
Hope this helps
Nat
kertz3
#6 Posted : Thursday, August 21, 2008 5:50:30 AM(UTC)
kertz3
Thanks for the help guys. The coupler did the trick. For 20 dollars and a half hour of work I saved at least a hundered bucks. Keep up the good work. I will be back if and when an appliance needs another repair.
libertyappl
#7 Posted : Thursday, August 21, 2008 8:13:18 AM(UTC)
libertyappl
Glad to assist.
Nat
Spin basket won't spin after trans replace (Washer Repair)
by cronaldallen 7/25/2014 9:20:25 AM(UTC)
Washer basket won't spin (Washer Repair)
by AlicePN 12/21/2013 11:26:48 AM(UTC)
Whirlpool washer basket won't spin (Washer Repair)
by mft7 9/5/2009 9:31:42 AM(UTC)
