owb520
#1 Posted : Saturday, August 16, 2008 12:53:49 PM(UTC)
owb520
The dryer will work properly for a short time and then the heat will shut off before the cloths are dry.
I have replaced the "Heat Control Switch" and the "Heat Sensor". I cleaned the inside of the dryer (all areas) and replaced the dryer exhaust line. I also checked for good continuity in all other vital parts (Coil, etc). I even removed the "Dryer Basket" and cleaned behind it!
1 - Will a bad "Moister Senor" cause the heat to shut off before clothes are dry?
2 - Can a bad "Coil" cause intermittent problems?
#2 Posted : Saturday, August 16, 2008 6:36:56 PM(UTC)
Most likely the problem is a bad gas valve coils. This is very common when the coils losing their resistance after they heated up. Any kind of problems with moister sensor are very rare.
- The part number for the kit of coils is AP2150379
owb520
#3 Posted : Sunday, August 17, 2008 12:39:39 PM(UTC)
owb520
Thank you very much.........
Maytag Neptune Dryer - heat will not stay on (Dryer Repair)
by creeker69 5/24/2012 6:51:55 PM(UTC)
by tonyck3239 8/4/2011 1:03:50 PM(UTC)
Neptune FL Gas Dryer-Heat will not stay on (Dryer Repair)
by mjzess 5/3/2010 6:33:08 AM(UTC)
by owb520 8/16/2008 1:03:07 PM(UTC)
