dyaros
#1 Posted : Friday, July 30, 2010 3:34:28 PM(UTC)
dyaros
My refrigerator quit working yesterday. No cooliing from refrigerator or freezer. Fans work blow warm air. Had a repair guy come out and his diagnosis was that the control board was bad. The compressor was trying to start and he couldn't tell if the compressor was still good. The only way to find out was to order the aprt and install it. I tried to locate the control board or controller online but cannot find anything close to that. He made it sound like it was the computer that controlled the refrigerator's function. Anyone have any idea?
#2 Posted : Friday, July 30, 2010 5:57:12 PM(UTC)
Your refrigerator is pretty simple. It does not have any electronic devices.
If the compressor is clicking, very likely the problem is a bad start relay/overload. There is a small chance for the compressor to be bad as well.
Due to inexpensive start relay/overload, I would replace it first.
- The start relay/overload kit Part number: AP3083556
dyaros
#3 Posted : Friday, July 30, 2010 6:52:25 PM(UTC)
dyaros
Thanks Gene. That makes sense. I am not sure what this guy was talking about then. All I know is that he was going to charge me $400 to try to fix it. Sounds like a lot for a $40 part.
Thanks again,
Dan
#4 Posted : Saturday, July 31, 2010 7:06:09 PM(UTC)
You are welcome Dan. Keep us posted.
dyaros
#5 Posted : Wednesday, August 4, 2010 6:03:56 PM(UTC)
dyaros
Gene. I was able to eventually install the kit tonight. The fridge appears to be working! Do you or anyone else know how the old harness plug is supposed to fit inside the new cover? There's a piece of plastic sticking out which prevents it from going all the way in. It seems that plastic would need to be cut to make it fit. The old harness dangling at the moment. Thanks!
#6 Posted : Thursday, August 5, 2010 8:57:30 PM(UTC)
You can do with this cover whatever you want. It would not hurt anything.
dyaros
#7 Posted : Sunday, August 8, 2010 4:07:13 PM(UTC)
dyaros
I ended up cutting the white wire connected to the harness and crimping a new insulated connector (Lowe's) to it then I connected it directly to the relay. I would recommend to anyone using this kit to do the same and save a lot of tinkering time. I can't see how the old harness was going to fit in that box along with the new relay. Fridge works like a charm. Thanks again... Now if I could just get my A/C fixed...
Dan
#8 Posted : Tuesday, August 10, 2010 12:03:18 PM(UTC)
You are welcome Dan. I'm glad you were able to fix it. Thank you for the feed back.
LG Refrigerator not cooling; compressor clicking. (Refrigerator & Freezer Repair)
by pmrowley 11/8/2023 7:07:53 AM(UTC)
Jenn-air refrigerator not cooling (Refrigerator & Freezer Repair)
by pke 9/20/2023 4:18:40 PM(UTC)
New GE refrigerator not cooling to set temp of 35 (Refrigerator & Freezer Repair)
by VarMan 6/16/2023 5:05:53 PM(UTC)
Freezerless Refrigerator not cooling (Refrigerator & Freezer Repair)
by rehawtho 7/19/2022 9:11:09 AM(UTC)
Whirlpool Refrigerator Not Cooling - Intermittently (Refrigerator & Freezer Repair)
by ljsmith9999 2/3/2022 6:53:41 AM(UTC)
Please help me diagnos refrigerator not cooling (Refrigerator & Freezer Repair)
by beaverislander 1/1/2022 6:18:12 AM(UTC)
Refrigerator not cooling, beeping (Refrigerator & Freezer Repair)
by Rtff 12/22/2021 6:55:11 AM(UTC)
Whirpool Refigerator WRS342FIAB00 Refrigerator Not Cooling Consistently/ Freezer Cold (Refrigerator & Freezer Repair)
by edge10 7/10/2021 8:07:34 AM(UTC)
GE Refrigerator not cooling properly/ water not dispensing (Refrigerator & Freezer Repair)
by tatkins85 3/18/2021 6:48:15 AM(UTC)
LG Refrigerator not cooling or freezing (Refrigerator & Freezer Repair)
by jesliu88 1/23/2021 8:44:04 PM(UTC)
Refrigerator not cooling - only bottom portion of coils covered in frost (Refrigerator & Freezer Repair)
by redr8er 12/26/2018 10:38:33 AM(UTC)
Samsung Refrigerator Not Cooling (Refrigerator & Freezer Repair)
by viper1522 11/8/2018 4:50:22 AM(UTC)
Refrigerator not cooling, bottom freezer over freezing and frosty (Refrigerator & Freezer Repair)
by Libboo 10/13/2017 2:51:02 AM(UTC)
Refrigerator not cooling enough (Refrigerator & Freezer Repair)
by skibumynn 4/8/2017 1:48:40 PM(UTC)
Whirlpool Refrigerator not cooling (Refrigerator & Freezer Repair)
by MCW750 10/12/2016 7:25:49 AM(UTC)
