cas
#1 Posted : 17 years ago
cas
The microwave first started on the fritz when we would heat things and it seemed to over heat. Power would shut off, we could unplug let cool, replug in and it would work again. It did this a total of 4times over a 4wk period. The last two times it did not overheat, but just turned off. The last time there was a pop noise and sizzle and now will not turn on. There is no power at all, the digital screen is blank, the light does not turn on in the inside when the door is opened. What happened and is this economically fixable.
Thanks.
CAS
#2 Posted : 17 years ago
CAS,
One of the most common problems with Ewave microwaves is a loose blade on the cooling fan, causing the magnetron to overheat.
At this time looks like the magnetron, the magnetron TCO and the fan blade have to be replaced. I do not think this microwave is worth fixing.
Frigidaire FFHB2740PS2 No Power (Refrigerator & Freezer Repair)
by mnjeepmale 9 months ago
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 10 months ago
kenmore elite smartheat quietpak 9 control has no power (Dryer Repair)
by Guest about a year ago
Gdf520pgj2ww dishwasher no power (Dishwasher Repair)
by pbajr 2 years ago
GDF610PMJ5ES (GE Dishwasher) - No Power to LED Display (Dishwasher Repair)
by txwildcard 2 years ago
GE JVM1540DM5WW suddenly no power a few seconds into starting it. (Microwave Repair)
by Guest 2 years ago
Fridge - No power (Refrigerator & Freezer Repair)
Thermador t18id900lp no power (Refrigerator & Freezer Repair)
by whosurpopi 2 years ago
No power to ice and water in Frigidaire FFHS2311PFEA (Refrigerator & Freezer Repair)
by Slbno1 2 years ago
lg tromm dryer no power (Dryer Repair)
by Guest 3 years ago
Frigidaire FGHS2631PF4A No Power (Refrigerator & Freezer Repair)
by hpreston35 3 years ago
GE Dishwasher - No Power - Replaced Control Board, Wiring Harnes, and UI Board (Dishwasher Repair)
by aervin 3 years ago
No power or panel lights to GE Dryer (Dryer Repair)
No power to control panel Kenmore Elite dishwasher model 665.12793k311 (Garbage Disposer Repair)
by John Boof 3 years ago
Maytag washer no power (Washer Repair)
