The power went out in my house and since then the only thing on my stove that works is the Accu simmer burner, my oven no longer works nor any of the other burners will heat up. :confused: :confused:
Rank: Administration
Check the circuit breaker. If this is an electric oven, make sure both circuit breakers are ok.
If you need more help, post the oven model number.
