No water to ice maker, please confirm water inlet valve # AP4071381 is the correct part and should solve my problem. When I manually fill the tray with water, ice is made. I am assuming the problem is the valve.
thanks,:)
The valve is the correct one for your fridg, but I would first test the old one by sticking 115 volts to it and see if it pumps out water by loostening the water line from it.
