I have a frigidare Refrigerator and my tenant took the door off not sure why? But when he put it back on there is a gap at the top by the handle and going down the side by the handle. Can anyone help me with this?:confused:iiifri
Originally Posted by: Debbyt  I have a frigidare Refrigerator and my tenant took the door off not sure why? But when he put it back on there is a gap at the top by the handle and going down the side by the handle. Can anyone help me with this?:confused:iiifri How old is the unit ? Depending on age and model you may need to loosen the liner screws(under the door gasket, on the inside of the door) and force the door back into position and re tighten the screws. If the unit has no liner screws(solid core door 5 years old or less)you may have to tweak the door back into position(using a small wood block,and pressing in on the affected part of the door.
