washer will not drain. How do i tell if the pump is no good or it is the washer timer? i have checked the hoses and taken the pump off and it is not cloogged.
Originally Posted by: jwm423  washer will not drain. How do i tell if the pump is no good or it is the washer timer? i have checked the hoses and taken the pump off and it is not cloogged. Does the motor run in the drain / spin cycle ? If yes, suspect a mechanical failure in the pump itself,or a clog in the drain spout at the tub or a clog in the tub to pump hose. If the motor does not run in the drain/spin cycle, suspect the timer, I presume the washer does fill and wash, indicating a properly running motor and timer.
