Replaced an igniter about three weeks ago. All was well until last week it started to burn very hot with long sooty yellow flame. What should we look at?
Rank: Administration
I'm assuming you are talking about the bake burner for the lower oven. If that's not the case, let me know. Inspect the burner. Sounds like there might be a big hole burnt through the metal, probably right where the igniter is. The burner is #21 on this diagram. Let me know...
