when trying start dryer I get a huming noise but will not start.
Most likely the problem is a bad motor. You can run a simple test to verify it. Open the door, push and hold the door switch, push the start button and turn the drum manually. If it'll start then the motor has to be replaced. - The part number for the motor is AP2043571 Gene.
