Dave Whiting
#1 Posted : Sunday, August 10, 2008 11:29:50 AM(UTC)
Dave Whiting
I have a Hotpoint refrigerator that has humidity gathering at the top inside and than dripping onto the products and than leaking out the door.
#2 Posted : Monday, August 11, 2008 10:47:31 AM(UTC)
Most likely the problem is a clogged and/or frozen drain hole under the evaporator coil in the freezer. You have to remove the rear panel in the freezer to access it. You can use a hair dryer to defrost it.
Here are the break down diagrams for the Hotpoint refrigerator Model CTX14CYTBRWH
