smithmr
#1 Posted : Friday, July 23, 2010 9:55:33 AM(UTC)
smithmr
Maytag Double Oven: The top ovens bake element has stopped working, I assume the element is shot, however after removing the element and checking with ohm meter it has continuity. So I probed all visible thermostat and connections and found all to read good. I did notice that one of the plugs on the circuit board was not fully seated, so I hoped this might be the culprit. Not, of course LOL. Anyway as I powered the oven up to test this I noticed that on the disply it showed H3 to the left of the clock. I assume this is a trouble code, and it only displays upon resetting power?? I have searched for this online however have not found an answer yet. Any help on getting to the bottom of the problem will be greatly appreciated.
Mark
smithmr
#2 Posted : Friday, July 23, 2010 10:58:42 AM(UTC)
smithmr
Ok after looking at this again, i realize the code at startup is H3 131, so that means that some of the other information that I found is relevent, sounds like the board is bad. Now to find a replacement.
#3 Posted : Friday, July 23, 2010 2:44:03 PM(UTC)
Sounds like the problem is a bad control board. You have to order the new overlay because it is glued on.
- The control board Part number: AP4358958
