js2008
#1 Posted : Thursday, August 7, 2008 7:10:26 AM(UTC)
js2008
Dryer starts when I press the start buttom but stops immediatelly when I let go. If I hold buttom down it runs.
oldcars
#2 Posted : Saturday, August 30, 2008 4:13:11 PM(UTC)
oldcars
I have the same problem, wish SOMEONE would help.
libertyappl
#3 Posted : Saturday, August 30, 2008 9:35:22 PM(UTC)
libertyappl
Please post your model numbers off of your machines, should be located on the dryer (open the door and look around the opening)
Nat
js2008
#4 Posted : Sunday, August 31, 2008 7:21:28 AM(UTC)
js2008
Model # 110.63952101
libertyappl
#5 Posted : Sunday, August 31, 2008 8:19:50 AM(UTC)
libertyappl
Open the control panel and located the tech sheet. On the tech sheet in the wiring diagram locate the start switch and follow the lines test all components in that line for continuity you can trace it that way. Without seeing the tech sheet myself I think when you hold the start button down it bypasses the door switch(going from memory). I will try to locate the tech sheet on line and look for certain.
