J.C. SMITH
#1 Posted : Tuesday, July 20, 2010 1:46:41 PM(UTC)
J.C. SMITH
Temperture Selector shaft broken. The shaft has gears on half of the shaft but diagram doesn't show any part that it would fit. Any suggestions.
#2 Posted : Tuesday, July 20, 2010 3:55:57 PM(UTC)
Originally Posted by: J.C. SMITH Go to Quoted Post
Temperature Selector shaft broken. The shaft has gears on half of the shaft but diagram doesn't show any part that it would fit. Any suggestions.
There is no Temperature Selector shaft in this dryer. The only shaft it has is the Cycle Selector shaft (#28 on the diagram).
- The cycle selector shaft Part number: AP3689826
is the OEM part made by Whirlpool for this dryer. You have nothing to worry about because if this part is incorrect, you can return it within 45 days.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KEHS01PWH1 Electric Dryer | AppliancePartsPros.com
J.C. SMITH
#3 Posted : Tuesday, July 20, 2010 6:12:06 PM(UTC)
J.C. SMITH
Thanks Gene,
That is what I ordered, but something caused the shaft to be in a bind and that is what I am trying to find out. What does the selector shaft fit into? Nothing I see in the parts diagram.
