Temperture Selector shaft broken. The shaft has gears on half of the shaft but diagram doesn't show any part that it would fit. Any suggestions.
Originally Posted by: J.C. SMITH  Temperature Selector shaft broken. The shaft has gears on half of the shaft but diagram doesn't show any part that it would fit. Any suggestions. There is no Temperature Selector shaft in this dryer. The only shaft it has is the Cycle Selector shaft (#28 on the diagram). - The cycle selector shaft Part number: AP3689826
Originally Posted by: Gene  There is no Temperature Selector shaft in this dryer. The only shaft it has is the Cycle Selector shaft (#28 on the diagram). - The cycle selector shaft Part number: AP3689826
Thanks Gene, That is what I ordered, but something caused the shaft to be in a bind and that is what I am trying to find out. What does the selector shaft fit into? Nothing I see in the parts diagram.
