I have replaced water filter 3 times while I have had unit. The last time water coming out of despenser was at low volume before I replaced the filter now with new filter it comes out good for about 1-2 seconds then down to a drip!!! What should I do to find out what the problem is? Thanks for any help!!!!
The fist thing you may want to check is the water pressure in the incoming water line. If there is nothing wrong, then the problem more likely is a bad water inlet valve. - The water inlet valve Part number: AP3160649
Originally Posted by: Gene  The fist thing you may want to check is the water pressure in the incoming water line. If there is nothing wrong, then the problem more likely is a bad water inlet valve. - The water inlet valve Part number: AP3160649
Gene. Thank's I did and vavle was clogged so very little water was coming out. I replaced vavle and all is good. Thank's Again!!!
Water vavle was plugged replaced all is good now!!! Thank's again!!
