Ruff
#1 Posted : Tuesday, July 20, 2010 1:00:52 PM(UTC)
Ruff
I have replaced water filter 3 times while I have had unit. The last time water coming out of despenser was at low volume before I replaced the filter now with new filter it comes out good for about 1-2 seconds then down to a drip!!! What should I do to find out what the problem is? Thanks for any help!!!!
#2 Posted : Tuesday, July 20, 2010 3:06:50 PM(UTC)
The fist thing you may want to check is the water pressure in the incoming water line.
If there is nothing wrong, then the problem more likely is a bad water inlet valve.
- The water inlet valve Part number: AP3160649
Ruff
#3 Posted : Tuesday, July 20, 2010 8:16:13 PM(UTC)
Ruff
Thank's I did and vavle was clogged so very little water was coming out. I replaced vavle and all is good. Thank's Again!!!
Ruff
#4 Posted : Tuesday, July 20, 2010 8:17:52 PM(UTC)
Ruff
Water vavle was plugged replaced all is good now!!! Thank's again!!
