Stingray
#1 Posted : Tuesday, July 13, 2010 10:07:14 AM(UTC)
Stingray
Motor has a high pitch squeal, but still seems to work ok during wash cycle. Very annoying. I took everything apart and the only thing I could see was some corrosion around the motor near the pump voute end as if there is a small leak. Everything seems OK otherwise, I oiled the motor shaft and put it all back together. Mild improvement. Am I correct to replace the motor and seal? Very expensive $125+- Thanks.
revndave
#2 Posted : Tuesday, July 13, 2010 3:52:33 PM(UTC)
revndave
I would replace complete motor/pump assy.Alot easier than replacing seal and motor.
//UserPostedImage UserPostedImage UserPostedImage UserPostedImageView Cart|Home|New Search|Search HelpUserPostedImage HELP DESK 1-877-477-7278 [IMG]https://server.iad.liveperson.net/hc/66305761/?cmd=repstate&site=66305761&&ver=1&imageUrl=https://www.appliancepartspros.com/img/livehelp/text[/IMG] E-mail UserPostedImageUserPostedImageReplacement parts in Pump and Motor Parts section of WHIRLPOOL KUDS01DLSS2 Undercounter Dishwasher
Owner manual for WHIRLPOOL KUDS01DLSS2 Undercounter Dishwasher
Download
UserPostedImage
UserPostedImageUserPostedImageUserPostedImage
Example: belt
Open this diagram in new Window UserPostedImage
AppliancePartsPros.com | Pump and Motor Parts replacement parts for Whirlpool KUDS01DLSS2 Undercounter Dishwasher
UserPostedImage
Diagram
LocationPart Photo Part DescriptionPriceAvailability Add to Cart
1 UserPostedImage
Enlarge Photo
Accumulator assembly
Part Number: AP3609773 made by WHIRLPOOL $66.92
In Stock
Order now and it will ship Wednesday
UserPostedImage
2 UserPostedImage
Enlarge Photo
Motor shield
Part Number: AP3039249 made by WHIRLPOOL $18.07
In Stock
UserPostedImage
3 UserPostedImage
Enlarge Photo
Screw
Part Number: AP3039183 made by WHIRLPOOL $3.91
In Stock
UserPostedImage
4 UserPostedImage
Enlarge Photo
Sump assembly - Seal included. The Hole For The Thermistor Should Be 31 To 31.5mm If Hole Is 35mm Then It Is AP3866228.
Part Number: AP3775547 made by WHIRLPOOL $49.15
In Stock
UserPostedImage
5 UserPostedImage
Enlarge Photo
Valve-chek
Part Number: AP3175191 made by WHIRLPOOL $10.04
In Stock
UserPostedImage
6 UserPostedImage
Enlarge Photo
Chopper assembly
Part Number: AP3039186 made by WHIRLPOOL $13.86
In Stock
UserPostedImage
7 UserPostedImage
Enlarge Photo
Screw - Size: 8-18 x 1-5/8 inch.
Part Number: AP3010928 made by WHIRLPOOL $3.05
In Stock
UserPostedImage
8 UserPostedImage
Enlarge Photo
Protector
Part Number: AP3851156 made by WHIRLPOOL $33.52
In Stock
UserPostedImage
9 UserPostedImage
Enlarge Photo
Protector
In Stock
UserPostedImage
10 UserPostedImage
Enlarge Photo
Motor assembly - Dishwasher motor assembly. Includes volute, shaft seal, and impeller.
Part Number: AP3179651 made by WHIRLPOOL $138.44
In Stock
UserPostedImage
11 UserPostedImage
Enlarge Photo
Screw
Part Number: AP3039190 made by WHIRLPOOL $3.68
Out of stock
Usually ships within 5 - 6 days
UserPostedImage
12 UserPostedImage
Enlarge Photo
Screen, pump sump
Part Number: AP3039191 made by WHIRLPOOL $16.69
Out of stock
UserPostedImage
13 UserPostedImage
Enlarge Photo
Gasket, Pump sump
Part Number: AP3039162 made by WHIRLPOOL $18.57
In Stock
UserPostedImage
14 UserPostedImage
Enlarge Photo
Complete pump and motor assembly - Original Whirlpool Part. Fits Whirlpool and KitchenAid dishwashers. This dishwasher pump and motor kit comes pre-assembled for easy installation.
Part Number: AP3778061 made by WHIRLPOOL $164.88
Out of stock
UserPostedImage
15 UserPostedImage
Enlarge Photo
tab, sump
Part Number: AP3174344 made by WHIRLPOOL $9.30
In Stock
UserPostedImage
16 UserPostedImage
Enlarge Photo
Nut
Part Number: AP3081222 made by WHIRLPOOL
Requires special attention
Please give us a call at
1-877-477-7278
17 UserPostedImage
Enlarge Photo
Dishwasher drain pump
Part Number: AP3133590 made by WHIRLPOOL $43.76
In Stock
UserPostedImage
18 UserPostedImage
Enlarge Photo
VOLUTE
Part Number: AP4502038 made by WHIRLPOOL $8.60
In Stock
UserPostedImage
19 UserPostedImage
Enlarge Photo
Hose, drain
Part Number: AP4399659 made by WHIRLPOOL $10.82
In Stock
UserPostedImage
20 UserPostedImage
Enlarge Photo
MOTOR-PUMP
Part Number: AP4434021 made by WHIRLPOOL $112.20
In Stock
UserPostedImage
21 UserPostedImage
Enlarge Photo
VOLUTE
In Stock
UserPostedImage
22 UserPostedImage
Enlarge Photo
Impeller
Part Number: AP3738238 made by WHIRLPOOL $17.60
In Stock
UserPostedImage
23 UserPostedImage
Enlarge Photo
Motor shaft seal
Part Number: AP3120026 made by WHIRLPOOL $13.15
In Stock
UserPostedImage
24 UserPostedImage
Enlarge Photo
Clamp, spring tension hose
Part Number: AP3039180 made by WHIRLPOOL $3.39
In Stock
UserPostedImage
25 UserPostedImage
Enlarge Photo
Thermister
Part Number: AP3039201 made by WHIRLPOOL $44.68
In Stock
UserPostedImage
26 UserPostedImage
Enlarge Photo
CAPACITOR
Part Number: AP4420627 made by WHIRLPOOL $49.63
In Stock
UserPostedImage
27 UserPostedImage
Enlarge Photo
Shield, capacitor
Part Number: AP3178889 made by WHIRLPOOL $4.03
In Stock
UserPostedImage
28 UserPostedImage
Enlarge Photo
Drain pump shield
Part Number: AP3081223 made by WHIRLPOOL $15.20
Out of stock
UserPostedImage
29 UserPostedImage
Enlarge Photo
Pressure switch shield
Part Number: AP3082693 made by WHIRLPOOL $11.64
In Stock
UserPostedImage
30 UserPostedImage
Enlarge Photo
Washer
Part Number: AP3179654 made by WHIRLPOOL $3.94
In Stock
UserPostedImage
Back to HomeSitemap | Legal Notice | Privacy Notice ©2000 - 2009 AppliancePartsPros.comâ„¢. All rights reserved.
// var lpNumber = '66305761'; var lpServerName = 'server.iad.liveperson.net'; function repStateNotifyFunction(state) { if (state == LPREPSTATEOFFLINE) { var lplink = document.getElementById("livepersonad") if (lplink != null) { lplink.href = 'http://www.appliancepartspros.com/customerservice/contact.aspx'; lplink.target = ''; lplink.onclick = ''; } } } var gaJsHost = (("https:" == document.location.protocol) ? "https://ssl." : "http://www.");document.write(unescape("%3Cscript src='" + gaJsHost + "google-analytics.com/ga.js' type='text/javascript'%3E%3C/script%3E")); try { var pageTracker = _gat._getTracker("UA-216729-1"); pageTracker._trackPageview(); } catch (err) { }if(typeof(_gat)!='object')document.write('')try {var gwoTracker=_gat._getTracker("UA-5527066-2");gwoTracker._trackPageview("/4071251349/test");}catch(err){}
