About Us
Appliance Parts
My Account
Order Status
Shop for Parts
Get Repair Help
Welcome Guest! To enable all features please
Login
or
Register
Forum
Active Topics
Search
Help
Login
Register
OK
AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
high pitch motor squeal
New Topic
Post Reply
Email this topic
Watch this topic
Print this topic
» Normal
Threaded
Model:
KUDS01DLSS2
Brand: Kitchen Aid
Age: 1 - 5 years
Previous Topic
Next Topic
Stingray
#1
Posted :
Tuesday, July 13, 2010 10:07:14 AM(UTC)
Multi-Quote
Motor has a high pitch squeal, but still seems to work ok during wash cycle. Very annoying. I took everything apart and the only thing I could see was some corrosion around the motor near the pump voute end as if there is a small leak. Everything seems OK otherwise, I oiled the motor shaft and put it all back together. Mild improvement. Am I correct to replace the motor and seal? Very expensive $125+- Thanks.
User Profile
View All Posts by User
View Thanks
By Model Number
By Part Description
By Part Number
powered by
revndave
#2
Posted :
Tuesday, July 13, 2010 3:52:33 PM(UTC)
Multi-Quote
I would replace complete motor/pump assy.Alot easier than replacing seal and motor.
View Cart
Home
New Search
Search Help
HELP DESK
1-877-477-7278
[IMG]https://server.iad.liveperson.net/hc/66305761/?cmd=repstate&site=66305761&&ver=1&imageUrl=https://www.appliancepartspros.com/img/livehelp/text[/IMG]
E-mail
Replacement parts in Pump and Motor Parts section of WHIRLPOOL KUDS01DLSS2 Undercounter Dishwasher
1
Door and Panel Parts
2
Control Panel Parts
3
Door and Latch Parts
4
Lower Washarm and Strainer Parts
5
Heater Parts
6
Fill and Overfill Parts
7
Tub and Frame Parts
8
9
Upper Rack and Track Parts
10
Lower Rack Parts
11
Upper Wash and Rinse Parts
12
Miscellaneous Parts Optional Parts (not Included)
Owner manual for WHIRLPOOL KUDS01DLSS2 Undercounter Dishwasher
Download
Example: belt
Open this diagram in new Window
AppliancePartsPros.com | Pump and Motor Parts replacement parts for Whirlpool KUDS01DLSS2 Undercounter Dishwasher
Diagram
LocationPart Photo Part DescriptionPriceAvailability Add to Cart
1
Enlarge Photo
Accumulator assembly
Part Number:
AP3609773
made by WHIRLPOOL $66.92
In Stock
Order now and it will ship Wednesday
2
Enlarge Photo
Motor shield
Part Number:
AP3039249
made by WHIRLPOOL $18.07
In Stock
3
Enlarge Photo
Screw
Part Number:
AP3039183
made by WHIRLPOOL $3.91
In Stock
4
Enlarge Photo
Sump assembly
- Seal included. The Hole For The Thermistor Should Be 31 To 31.5mm If Hole Is 35mm Then It Is AP3866228.
Part Number:
AP3775547
made by WHIRLPOOL $49.15
In Stock
5
Enlarge Photo
Valve-chek
Part Number:
AP3175191
made by WHIRLPOOL $10.04
In Stock
6
Enlarge Photo
Chopper assembly
Part Number:
AP3039186
made by WHIRLPOOL $13.86
In Stock
7
Enlarge Photo
Screw
- Size: 8-18 x 1-5/8 inch.
Part Number:
AP3010928
made by WHIRLPOOL $3.05
In Stock
8
Enlarge Photo
Protector
Part Number:
AP3851156
made by WHIRLPOOL $33.52
In Stock
9
Enlarge Photo
Protector
Part Number:
AP3851156
In Stock
10
Enlarge Photo
Motor assembly
- Dishwasher motor assembly. Includes volute, shaft seal, and impeller.
Part Number:
AP3179651
made by WHIRLPOOL $138.44
In Stock
11
Enlarge Photo
Screw
Part Number:
AP3039190
made by WHIRLPOOL $3.68
Out of stock
Usually ships within 5 - 6 days
12
Enlarge Photo
Screen, pump sump
Part Number:
AP3039191
made by WHIRLPOOL $16.69
Out of stock
13
Enlarge Photo
Gasket, Pump sump
Part Number:
AP3039162
made by WHIRLPOOL $18.57
In Stock
14
Enlarge Photo
Complete pump and motor assembly
- Original Whirlpool Part. Fits Whirlpool and KitchenAid dishwashers. This dishwasher pump and motor kit comes pre-assembled for easy installation.
Part Number:
AP3778061
made by WHIRLPOOL $164.88
Out of stock
15
Enlarge Photo
tab, sump
Part Number:
AP3174344
made by WHIRLPOOL $9.30
In Stock
16
Enlarge Photo
Nut
Part Number:
AP3081222
made by WHIRLPOOL
Requires special attention
Please give us a call at
1-877-477-7278
17
Enlarge Photo
Dishwasher drain pump
Part Number:
AP3133590
made by WHIRLPOOL $43.76
In Stock
18
Enlarge Photo
VOLUTE
Part Number:
AP4502038
made by WHIRLPOOL $8.60
In Stock
19
Enlarge Photo
Hose, drain
Part Number:
AP4399659
made by WHIRLPOOL $10.82
In Stock
20
Enlarge Photo
MOTOR-PUMP
Part Number:
AP4434021
made by WHIRLPOOL $112.20
In Stock
21
Enlarge Photo
VOLUTE
Part Number:
AP4502038
In Stock
22
Enlarge Photo
Impeller
Part Number:
AP3738238
made by WHIRLPOOL $17.60
In Stock
23
Enlarge Photo
Motor shaft seal
Part Number:
AP3120026
made by WHIRLPOOL $13.15
In Stock
24
Enlarge Photo
Clamp, spring tension hose
Part Number:
AP3039180
made by WHIRLPOOL $3.39
In Stock
25
Enlarge Photo
Thermister
Part Number:
AP3039201
made by WHIRLPOOL $44.68
In Stock
26
Enlarge Photo
CAPACITOR
Part Number:
AP4420627
made by WHIRLPOOL $49.63
In Stock
27
Enlarge Photo
Shield, capacitor
Part Number:
AP3178889
made by WHIRLPOOL $4.03
In Stock
28
Enlarge Photo
Drain pump shield
Part Number:
AP3081223
made by WHIRLPOOL $15.20
Out of stock
29
Enlarge Photo
Pressure switch shield
Part Number:
AP3082693
made by WHIRLPOOL $11.64
In Stock
30
Enlarge Photo
Washer
Part Number:
AP3179654
made by WHIRLPOOL $3.94
In Stock
Back to Home
Sitemap
Legal Notice
Privacy Notice
©2000 - 2009 AppliancePartsPros.comâ„¢. All rights reserved.
// var lpNumber = '66305761'; var lpServerName = 'server.iad.liveperson.net'; function repStateNotifyFunction(state) { if (state == LPREPSTATEOFFLINE) { var lplink = document.getElementById("livepersonad") if (lplink != null) { lplink.href = 'http://www.appliancepartspros.com/customerservice/contact.aspx'; lplink.target = ''; lplink.onclick = ''; } } } var gaJsHost = (("https:" == document.location.protocol) ? "https://ssl." : "http://www.");document.write(unescape("%3Cscript src='" + gaJsHost + "google-analytics.com/ga.js' type='text/javascript'%3E%3C/script%3E")); try { var pageTracker = _gat._getTracker("UA-216729-1"); pageTracker._trackPageview(); } catch (err) { }if(typeof(_gat)!='object')document.write('')try {var gwoTracker=_gat._getTracker("UA-5527066-2");gwoTracker._trackPageview("/4071251349/test");}catch(err){}
User Profile
View Thanks
Quick Reply
Show Quick Reply
Security Image:
Enter The Letters From The Security Image:
Guest
New Topic
Post Reply
Dishwasher Repair
- Dishwasher Repair
- Dryer Repair
- Garbage Disposer Repair
- Heating, Ventilation, and Air Conditioning (HVAC)
- Microwave Repair
- Oven Repair (including Ranges and Cooktops)
- Refrigerator & Freezer Repair
- Trash Compactor Repair
- Washer Repair
- Blender Repair
- Appliance Parts
- Forum Announcements
- General Talk
Local Appliance Repair Companies
- Appliance Repair Companies - East of the Mississippi
- Appliance Repair Companies - West of the Mississippi
You
can
post new topics in this forum.
You
can
reply to topics in this forum.
You
can
delete your posts in this forum.
You
can
edit your posts in this forum.
You
cannot
create polls in this forum.
You
can
vote in polls in this forum.
Privacy Policy
Powered by YAF.NET
YAF.NET © 2003-2024, Yet Another Forum.NET
