lindav
#1 Posted : Monday, July 12, 2010 1:09:39 PM(UTC)
lindav
Do I need to replace the water valve?
#2 Posted : Monday, July 12, 2010 4:19:54 PM(UTC)
Check if the water feeding tube is properly connected to the ice maker, so the water is going straight into the ice maker.
If there is nothing wrong and the ice maker overflows, replace the water inlet valve.
- The water inlet valve Part number: AP2115312
