AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
water leak at the very back of icemaker and freezes at top of bin
Do I need to replace the water valve?
Check if the water feeding tube is properly connected to the ice maker, so the water is going straight into the ice maker. If there is nothing wrong and the ice maker overflows, replace the water inlet valve. - The water inlet valve Part number: AP2115312
