High pitch sound coming from fridge when I push water dispenser. Replaced water inlet valve & filter. Checked lines for ice (not). Dispenser works but no water to ice maker. Swaped out plug on water valve then water ran down from the front of the freezer door under the dispenser panel. Could it be a bad water valve despite being brand new? Also tried jumper test. T&H that made a high pitched sound but no water to ice maker. Weird:eek:
