My dryer blows cold air . I made sure that the vent was clean ,I checked continuity with the fuse, which is good. The dryer is spinning and the timer is working. To add to info, 2 days ago i cleaned the blower and vent duct from lent, it wasn't an excessive amount of lint and it started blowing hot air, now 2 days later it's blowing cold air again, also I must add it is coin-op. i am interested in replacing all pats that would be related with in reason to make it a onetime blanket event since I have everything apart, to avoid having to open her back up to change another part.
Thank You! Charles
Hi Charles, There are five major electrical parts involved in the heating process: 1. Thermal fuse 2. Cycling thermostat 3. Igniter 4. Flame sensor 5. Gas valve coils How to find out which part causing the problem? Pretty simple: all of these parts have to be tested for continuity in the above sequence. If any of them is open – it has to be replaced. If the thermal fuse is blown – it has to be replaced together with the cycling thermostat. Gas valve coils also could be tested by resistance. There are two coils – one with three terminals and one with two terminals. 1. Coil with two terminals should have 1220 ± 50 Ohms 2. Coil with three terminals if held with terminals in upper position: a) across the left and the middle terminals – 1365 ± 25 Ohms b) across the left and the right terminals – 560 ± 25 Ohms |
