charles beal
#1 Posted : Friday, July 9, 2010 11:09:44 AM(UTC)
charles beal
My dryer blows cold air . I made sure that the vent was clean ,I checked continuity with the fuse, which is good. The dryer is spinning and the timer is working. To add to info, 2 days ago i cleaned the blower and vent duct from lent, it wasn't an excessive amount of lint and it started blowing hot air, now 2 days later it's blowing cold air again, also I must add it is coin-op. i am interested in replacing all pats that would be related with in reason to make it a onetime blanket event since I have everything apart, to avoid having to open her back up to change another part.
Thank You!
Charles
#2 Posted : Friday, July 9, 2010 2:47:23 PM(UTC)
Hi Charles,
There are five major electrical parts involved in the heating process:
1. Thermal fuse
2. Cycling thermostat
3. Igniter
4. Flame sensor
5. Gas valve coils
How to find out which part causing the problem?
Pretty simple: all of these parts have to be tested for continuity in the above sequence.
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter
If any of them is open – it has to be replaced.
If the thermal fuse is blown – it has to be replaced together with the cycling thermostat.
Gas valve coils also could be tested by resistance. There are two coils – one with three terminals and one with two terminals.
1. Coil with two terminals should have 1220 ± 50 Ohms
2. Coil with three terminals if held with terminals in upper position:
a) across the left and the middle terminals – 1365 ± 25 Ohms
b) across the left and the right terminals – 560 ± 25 Ohms
- The thermal fuse Part number: AP3132867
- The cycling thermostat Part number: AP3131939
- The igniter kit Part number: AP3094138
- The flame sensor Part number: AP2910747
- The coil kit Part number: AP3094251
dryer blowing cold air, dial not advancing through cycle (Dryer Repair)
by stoik1978 12/19/2011 9:23:36 AM(UTC)
